DIAdem
Which variable is the return value of the "OrdAT ParaSet" command returned to?
The return value of the "OrdAFParaSet" command is returned in the "GenXBegin", "GenXEnd", and "OrdAFRevolStep" variables. Which variable is the return value of "OrdATParaSet" returned to?
No results are returned for "OrdATORedBegin", "OrdATORedEnd", or "OrdATORedStep".
(1,890 Views)
Hello SEVEN X,
you can find more information here: Command: ChnOrdATCalc - DIAdem 2018 Help - National Instruments (ni.com)
Also, in the DIAdem help file.
Best Regards,
Edgar
(1,813 Views)
Accepted by SEVEN_X
Just for Info:
The command OrdAFParaSet() sets these variables:
GenXBegin, GenXEnd and OrdAFRevolStep
The command OrdATParaSet() sets these variables (depending on the settings in the dialog - OrdATORedType)
OrdATOFreqMin, OrdATOFreqMax, OrdATORedBegin, OrdATORedEnd, OrdATORedFactor and OrdATORedStep.
Greetings
Walter
(1,805 Views)
