DIAdem
Working with waveform properties in Python
I'm trying to work with waveform data and having a bit of trouble with time calculations.
The challenge is that the data type of start time / offset and increment are not compatible.
For example simply adding start time and increment like this:
dd.Data.Root.ActiveChannelGroup.Channels("DUT 01").Properties("wf_start_time").Value
+ dd.Data.Root.ActiveChannelGroup.Channels("DUT 01").Properties("wf_increment").Value
results in a
TypeError: unsupported operand type(s) for +: 'pywintypes.datetime' and 'float'
I'm not familiar with pywintypes and haven't really looked into this library yet.
But i have tried converting to datetime with no luck.
Is there maybe a simple "How-to" for handling time data in with Python in DIAdem?
(2,303 Views)
Accepted by maflAut
to add those values it is possible to import "datetime" and to use the function "timedelta".
Below you find a short example, adding step width of one day to the waveform start time.
"timedelta" offers also options to add the value to month, year etc.
import datetime
StartTimeVal=dd.Data.Root.ChannelGroups(1).Channels("DUT 01").Properties("wf_start_time").Value
StepWidthVal=dd.Data.Root.ChannelGroups(1).Channels("DUT 01").Properties("wf_increment").Value
StartTimeVal=StartTimeVal+datetime.timedelta(days=StepWidthVal)
With
wf_start_time: 01.08.2012 00:00:00.000000000
wf_increment: 1
you receive:
wf_start_time 02.08.2012 00:00:00.000000000
(2,248 Views)
Thank you!
(2,223 Views)
