DIAdem
X-Chanel must be equidistant ?!?!?
Hi there
With the analysis function "numeric channel to waveform" I had the error "The x-channel must be equidistant" several times now, although the x-channel and the y-channel have the same length.
What am I doing wrong?
In the attachment, you find the signals.
Greetings
Ruffy
(2,097 Views)
Accepted by Ruffy_LR
If you convert to waveform you are converting your x channel to formular channel
val(n) = offset + factor * n
to be successful you x-channel must be equidistant.
This means if you calculate the delat of you x channel it should be constant.
No as a human being you could argue that it is always 0.4 bt looking on the preview shows you that the computer will never believe this is a constant value.
So either you need to quantizie the values or you you have to stay with an time channel.
(2,076 Views)
"Equidistant" means that the distance between adjacent points is the same for all points, i.e. graphing [x vs. index] would be a straight line. Nothing to do with the data length.
(2,070 Views)
