DIAdem
Y axis auto scale not working in DIAdem 11
Hi
A few years ago I created a user dialog box for selecting and displaying channels in DIAdem view.
It worked fine for all DIAdem 10.X releases, but for DIAdem 11.X there is a problem with the y-axis scaling.
The channels are displayd as [n  Systems (Linear)]
In DIAdem 10.X the y-axis for each separate graph would be scaled automatically accoring to the min. and max. values of the displayed channel.
In DIAdem 11.X the y-axis for each graph is scaled from 55.0397 to 133.7655.... for all channels, no matter what the values are for the displayed channel.
When I click the "Zoom Off" button the scaling becomes correct.
What do I need to put in to my script to make the y-axis scale correctly?
Below is the code that is used to set the scaling (no scaling for Y axis is set):
    R1 = SelectedStartTime 'this is a variable defined earlier in the code
    R2 = SelectedEndTime 'this is a variable defined earlier in the code
    View.ActiveSheet.Cursor.X1 = R1
    View.ActiveSheet.Cursor.X2 = R2
    View.ActiveSheet.Areas(1).DisplayObj.XScaling = "RangeZoom"
I've tried adding this code, to no effect:
    View.ActiveSheet.Areas(1).DisplayObj.YScaling = "n systems [phys.]"
    View.ActiveSheet.Areas(1).DisplayObj.YScalingMode = "automatic"
(5,256 Views)
I might also add, if I remove this line from the original code:
The code works fine also in DIAdem 11.X (except that the X-scaling of course isn't assigned)
In other words, when the XScalin property is set it also affects the Y-axis scaling somehow.
(5,252 Views)
I tried with Macro recording and Ctrl+A and the result was
Option Explicit  'Forces the explicit declaration of all the variables in a script.
R1 = 30
R2 = 52
Call View.NewLayout()
View.Sheets("Sheet 1").Areas("Area : 1").DisplayObjType = "CurveChart2D"
Dim oMyDisplayObj
Set oMyDisplayObj = View.Sheets("Sheet 1").Areas("Area : 1").DisplayObj
oMyDisplayObj.Curves.Add "[1]/Time", "[1]/Speed"
oMyDisplayObj.YScalingMode  ="automatic"
oMyDisplayObj.Abscissa ="X-Cursor"
oMyDisplayObj.Ordinate ="Y-Cursor"
View.Sheets("Sheet 1").Areas("Area : 1").DisplayObj.XScalingMode = "RangeZoom"
WndShow "VIEW", ""
which seems to work fine. So there is only one difference to your code which is
.XScalingMode
instead of XScaling. Does changing this work with your code?
(5,243 Views)
Accepted by salte
Thanks for you reply Andreas.
Your suggestion probably works well for DIAdem11.X, however I (preferrably) need solutions that work for both DIAdem 10.X and 11.X (so that the same script may be used for both versions).
In DIAdem 10.2 (which is the developer version I have) there doesn't appear to be any property called XScalingMode for CurveChart2D (only YScalingMode).
However, I did find something that worked for both versions, namely:
View.ActiveSheet.Areas(1).DisplayObj.ZoomCursor = "BandZoomCursor"
After setting this property (in addition to the code in my initial post) the graphs are scaled correctly (on both 10.X and 11.X).
(5,232 Views)
