DIAdem
activeX DIADEM
NI Diadem 10.2
Vorrei poter utilizzare i controlli ACTIVEX in DIADEM.
Ho trovato nel forum un'esempio di utilizzo del Microsoft Toolbar activeX.
Provato inserire il controllo MSComctlLib.Toolbar.2
Creato un buttonFile e un BottonMenu
Sub MSComctlLib4_EventButtonMenuClick(ButtonMenu)
Dim This : Set This = MSComctlLib4
    Set oButtonmenuT = ButtonMenu
    msgbox "<"& oButtonmenuT.key & ">"&" was pressed..."
    Set oButtonmenuT = Nothing
End Sub
 restituisce l'errore:
 <Object: MSComctlLib4', Event 'EventButtonMenuClick', line: 3>
Variabile non definita: 'obuttonmenuT'
 Stessa cosa con Microsoft TreeView
Dove è l'errore?
Come si fa a trattare i controlli ActiveX in DIADEM ?????
Grazie mille,
Yustas
(5,193 Views)
Hi Yustas,
Was that Italian?  I could make out parts of it using English and French cognates.  It sounds like you want to use an external ActiveX object as a control in a DIAdem SUDialog.  When I look at the list of registered ActiveX controls on my WinXP computer, I don't see anything resembling "MSComctlLib4".  Is that a control inside an ActiveX library of a different name?
The error message you listed, though, is just a syntax error-- you've used a variable ("oButtonmenuT") without defining it.  There are two ways of fixing this-- you can either define that new variable before using it, or you can just use the subroutine parameter as a variable:
    Dim oButtonmenuT
End Sub
    msgbox "<"& ButtonMenu.key & ">"&" was pressed..."
End Sub
Brad Turpin
DIAdem Product Support Engineer
(5,183 Views)
Thanks Brad. I have just tried out your piece of code and it works well.
It was a variable declarition problem.
I am trying to use MSComctlLib.Treectlr control activeX (TreeView)windows XP .
what can I do to creare nodes and manage this activeX control in Diadem?
I can't create "Node":
Sub MSComctlLib1_EventInitialize()
Dim This : Set This = MSComctlLib1
   Dim nd
    Set ND = Node  '???????????????????????????? but there isn't any Node
 Set nd = this.X.Nodes.add(, , "Root", "Ciao", "database")
End Sub
where is the error?
Thanks..
Yustas
Sorry for my bad english, but i speak only Italian or Russian:)
(5,180 Views)
Accepted by topic author Yustas
Hi Yustas,
What do you know, I found an application I worked on for another customer that used that same tree control in a SUDialog.  In that application these 2 methods added nodes:
Tree.X.Nodes.Add Null, 0, ParentName, ParentName
Set Node = Tree.X.Nodes.Add(ParentName, 4, ChildKey, ChildName)
Hope that helps,
Brad Turpin
(5,173 Views)
Ok. It works well.
Thanks Brad
Yustas
(5,157 Views)
