DIAdem
tdms file break down in parts
How do you break down a tdms file   down in chunks  of a certain  value
I have a file that  come from counter ,evry let say   20 counter value's respresent   1 turn
Now i want to have the whole file    in   turns     so evry 20 counter values     then compare them and see  how in  changes  .
This change  tells be a certain behavoir of a problem ( imbalance)
Now the the absolute values does not say evry thing since its not a constant speed   the speed is  slowly going down
I if  i see it like a wave form  and all  rotation on top of each other   like a waterfall plot.
But i have no idea how the cut this file in even parts    ,and make a waterfall plot
Some have a good idea how to do this?
Cees
Message 1 of 8
(4,559 Views)
Hi Cees,
It sounds like the first thing you want to do is convert your counter channel into a Cycles channel.  Then are you saying you want to break the data from each wheel revolution into its own channel so that you can display a waterfall graph?  You can create the waterfall graph in DIAdem without breaking out the data into separate channels once you have the Cycles channel.  A waterfall graph has 3 axes, what do you want on the 3rd axis?  So far we've got amplitude on the Z axis and Cycles on the X or Y axis.  What's the 3rd quantity?  I believe I've already sent you code to convert tachometer pulses to RPMs, it would be a minor adaptation to convert to Cycles instead.
Brad Turpin
DIAdem Product Support Engineer
Message 2 of 8
(4,532 Views)
Hi Brad
3rd axes would be deflection (distance)    of the amplitude in  time
Example   first sinus  Wave    has height   0  5  0 -5 0
last sinus  wave  0    20 0 -20 0
Thanks Brad
Message 3 of 8
(4,524 Views)
Hi Cees,
I'm struggling again to understand your English.  Would you please list the data that you want on X, Y, and Z axes?  Was I correct in guessing that you want Cycles (Revolutions, Periods) on one of the axes?
Brad Turpin
Message 4 of 8
(4,498 Views)
I am sorry for my bad english brad
yes your correct  about cycles (revs,rpm ,periods)
as NI explains 1 period
x  period   1 period  x 20  =  1 cycle  ,= 1 revolution
y amplitude
z nr cycles
Cees
Message 5 of 8
(4,485 Views)
Hi Cees,
Based on that graph, I'd say you need to sum the values of the counter channel, then devide them by 20 to give you a channel that tracks the number of cycles/periods.  The ChnSum() ANALYSIS routine will sum the channel, and the ChnLinScale() ANALYSIS routine will enable you to multiply it by 0.05.  Both of these ANALYSIS routines are available "Basic Mathematics" palette in ANALYSIS.  After that you can sort the values by the periods channels, sending all the Period=1 data to one Group, say, all the Period=2 data to another Group, etc.
Do I already have a data set like this from you?  I have so many that I can't tell any more which is which.
Brad Turpin
Message 6 of 8
(4,468 Views)
Hi Brad
I have sent the file's to your email adresse
cees
Message 7 of 8
(4,443 Views)
Sorry brad still struggling with it ,i simply do not get what i want thats why i posted  the file ,so you take a look at it if you want to show me (at least if you want and can) how to solve this
If i sum the file i get all period summed (values of it ) that not what i need,  i need 20 period  = i rev
i need avg of  that rev to find  the ( so called zero point ) then from  zero point then   this the amplitude.of all 20 period in that rev
so if i have as this file shows   6525 data periods    /20 =326.25  rev
So i want to see in waterfall graph all 326.25 rev
cees
Message 8 of 8
(4,343 Views)
