DIAdem
autosave during measuring in TDM-format
As we have long time measurements I want to save the data during recording. The autosaved file is a DAT file, but to avoid mismatch I would prefer to have TDM. Is there a possibility to set the autosave function to TDM-format.
Regards
Juergen
(3,389 Views)
Hello!
Which version of Diadem are you using?
The Save Block in Diadem DAC can save TDMs only from DIAdem 10.x
Best regards
Ken
(3,362 Views)
Thank you for the answer. In deed we only have Diadem 9.1, but I hoped there could be a hidden check box to switch from Dat to TDM .
Greetings
Juergen
(3,348 Views)
