Home
Community
Discussion Forums
Most Active Software Boards
DIAdem
Topic
DIAdem
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
autosave during measuring in TDM-format
jhirschbuehler
Member
02-02-2007
08:28 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
As we have long time measurements I want to save the data during recording. The autosaved file is a DAT file, but to avoid mismatch I would prefer to have TDM. Is there a possibility to set the autosave function to TDM-format.
Regards
Juergen
0
Kudos
Message
1
of 3
(3,385 Views)
Reply
Re: autosave during measuring in TDM-format
Ken_Tobler
Active Participant
02-07-2007
09:56 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Hello!
Which version of Diadem are you using?
The Save Block in Diadem DAC can save TDMs only from DIAdem 10.x
Best regards
Ken
1
Kudo
Message
2
of 3
(3,358 Views)
Reply
jhirschbuehler
Member
Author
02-08-2007
03:41 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Thank you for the answer. In deed we only have Diadem 9.1, but I hoped there could be a hidden check box to switch from Dat to TDM .
Greetings
Juergen
0
Kudos
Message
3
of 3
(3,344 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
