DIAdem
calculation on verse data
hello i am begginer in use diadem
could you  tell me how should look  function in calculator in some simply example. i have 2 chanell ,in 1 chanell i have data, in 2 chanel i want have the same data but not  in the same verse, so
chanel2,verse1= chanel1verse2 and this function schould work i all 2chanell
Message 1 of 10
(5,175 Views)
tut mir leid, aber so ganz habe ich die Aufgabenstellung noch nicht verstanden. Möchtest du Kanäle kopieren?
Gruß
Walter
Message 2 of 10
(5,169 Views)
i give the most simple example on calculation on verse data, not on chanell, in excel it will look that: in cell B2 will be function "=A1" ( when column A it is my first chanell and B second)
i just start use diadem and dont know that basic function, i  must analyse preasure in internal combustion engine, but firs i must know how i can do chanel which will be depend on other data in oder chanel and other VERSE
Message 3 of 10
(5,163 Views)
I’m not sure to understand what you mean with verse. I know verse in the content of poets and/or lyrics. For technical data it is unknown for me.
But, if you would like to copy a channel to have it twice you simply open the context menu (right click) of selected channel in the Dataportal and copy and paste it.
If you would like to define an equation you can open ANALYSIS an call the Calculatorof the command icon bar.
Greetings
Walter
Message 4 of 10
(5,159 Views)
vers it is line, when you have data numbers are in one kolumn exmaple:
             chanel : A                              B
line(verse)
1                       4,2                          0
2                       3,6                         4,2
3                       4,5                          3,6
4                       3,15                        4,5
 and in this example A1=B2
Message 5 of 10
(5,156 Views)
Hi zz,
The only reason I can think of to want to shift the rows up one from Ch1 to Ch2 is if you wat to subtract Ch2 from Ch1 to get the point by poin t delta of Ch1's values.  If this is what you want to do, please use the ANALYSIS function "Calculate Differences" (DELTA icon) in the "Basic Mathematcs" palette.  If this is not what you want to do with Ch1 and Ch2, what DO you want to do with this row-shifted data?
Brad Turpin
DIAdem Product Support Engineer
Message 6 of 10
(5,107 Views)
Hi zz,
maybe the following example does what you expect:
CHD(lineA,"YourChannelGroup/CHA" )= CHD( lineB, "YourChannelGroup/CHB" )
e.g.:
CHD(1,"YourChannelGroup/CHA" )= CHD(2, "YourChannelGroup/CHB" )
You can run this line in the diadem-calculator...
regards
romi_wo
Message 7 of 10
(5,105 Views)
Hi zz,
in this case you can copy the channel and delete the first value of the copy channel like:
Call ChnCopy(ChnNameA, ChnNameB)
Call DataBlDel(ChnNameB,1,1,1)
Greetings
Walter
Message 9 of 10
(5,071 Views)
hehe indeed it is way to copy chanell , reality i  must do more complicated function and i wil not copy chanel in my work i juts want know how i can make calculation on line, one of more complicated function what i must do in my work is:
chanell3 line5 = if (chanell2line4>0 , true=(chanell1line1+chanell1line2+chanell1line3+chanell1line4)/4,false=0) -that will look function in cell =chanell3line5, but i want have automatically in cell =chanell3line6 function:
chanell3 line6 = if (chanell2line5>0 , true=(chanell1line2+chanell1line3+chanell1line4+chanell1line5)/4,false=0)
Message 10 of 10
(5,067 Views)
