DIAdem
create 800hz time channel in Diadem
How do I create an 800Hz time channel using the "Create Time Channel" in the Analysis section of DiademIt will only allow intergers to be used as a time stepTo create a 1000Hz time channel I use a time unit of "miilisecond" and a time step of 1, for 100Hz time I use a time unit of "millisecond" and a time step of 10But for an 800Hz time channel using the "millisecond"time unit the time step would have to be 1.25 which Diadem will not accept.
I have other time frequencies that pose this problem, such as 325 Hz and so on.
Any help will be appreciated
John
(4,969 Views)
Hi John,
Use the "Generate Numeric Channel" dialog instead and just name the resulting channel "Time".  The "Generate Time Channel" dialog is for creating "date/time" channels in DIAdem, which unfortunately only have a resolution of 0.1 ms.
Brad Turpin
(4,947 Views)
If I use that command how do I input a start time in the hh:mm:ss.fff format.  I need to generate a time channel that coresponds to UTC time in order to sync all of the data that I record from different DAQ systems as well as UTC time stamped video.  I can start the time channel with 1 and increments .00125 (for 800 Hz) but then I cannot generate a real hh:mm:ss.fff channel.
(4,945 Views)
Hi John,
DIAdem can only display time channel values to a resolution of a tenth of a millisecond, but we can create a numeric channel which stores the full resolution of your time data and then toggle the "DisplayType" property to "Time" to trick that numeric channel into displaying as a date/time channel.  You still won't see the microsecond and tenth of a microsecond resolution in date/time display, but the values will be correct except for that limitation.  I'm attaching a VBScript function that does this (using DIadem 10.x commands).
Function CreateTimeChan(Name, StartTime, ScanRateHz, Length)
  Dim TimeChan, Period
  StartTime =
TTR(StartTime, "#mm/dd/yyyy hh:nn:ss.ffff")
  IF StartTime <= 0 THEN Exit Function
  IF ScanRateHz <= 0 THEN Exit Function
  Period = 1/ScanRateHz
  TimeChan = ChnLinGen(Name, 0, Length-1, Length)
  Call ChnLinScale(TimeChan, TimeChan, Period, StartTime)
  Call ChnPropValSet(TimeChan, "DisplayType", "Time")
  Call ChnPropValSet(TimeChan, "Unit_String", "s")
CreateTimeChan = TimeChan
End Function ' CreateTimeChan()
Brad Turpin
National Instrument
(4,932 Views)
Accepted by jjandascog
Thanks, that takes care of my issue
(4,905 Views)
