DIAdem
dataplugin for ISO
Hi all,
I have a file for example CL100-01, which on extractin gives me
CL100-01(ISO file)
CL100-01.001
CL100-01 (.002 file),
CL100-01.003,
CL100-01.004, ........ CL100-01.059.
What type of file is this? Do  i need any data plugin for this type of file?
If i select ASCII type in Data load dialog then all these 60 files inside CL100-01 file appears .
Then from all these 60 files which file do i have to load? Confused:(
(4,033 Views)
Accepted by RSH
Hi RSH,
That looks like an MME data set.  If you have the *.mme file that contains references to all the *.001, etc. channel files, then you just need to download the "MME_Import" DataPlugin from the www.ni.com/dataplugins web site.
Brad Turpin
(4,018 Views)
Thanks for the link.I downloaded the data plug dtr_13499 for *.iso and its working.
iso_mme data plugin dint help:(
(3,984 Views)
