DIAdem
detrend
 Hello.
I wonder if Diadem has any similar function as matlab’s Detrend function to correct the inclined offset of a signal or any other function for it.
(5,451 Views)
Hello.
I wonder if Diadem has any similar function as matlab’s Detrend function to correct the inclined offset of a signal or any other function for it. detrend_fft
(5,429 Views)
Hello Iker,
There is already a forum with exactcly the same question here:
http://forums.ni.com/t5/DIAdem/Matlab-Detrend-function-in-DIAdem/m-p/2496878
I hope in here you find the answer you are looking for!
Cristina
(5,423 Views)
Hi IKER,
Have you tried the ANALYSIS function "Digital Filters" in the "Signal Analysis" palette?   When I try the "High Pass" filter on a similar looking data set, it appears to do what you're after.  Feel free to post a data set if you want help with the filter parameters.
Brad Turpin
DIAdem Product Support Engineer
(5,409 Views)
 thanks, I have resolved.
(5,372 Views)
