DIAdem
disable inbuilt diadem functions
Hi I'm accessing a database and I need to use the find method of the ADO recordset object
i.e. record_set.find("column1 = 10")
However diadem uses the inbuilt find function instead of the find method associated with the recordset
Can I stop diadem doing this?
Thanks for your help
Also I'm trying to avoid running too many SQL queries as they seem to be quite slow
(4,129 Views)
Hi lewis.may,
If you are executing the line of code you submitted, I cannot imagine DIAdem calling the Find() function instead of running the "Find" method of the record_set object.  DIAdem absolutely respects name space arguments and has no trouble calling methods of external objects, such as ADO objects.
Could you provide the relevant code you're running that causes the unexpected behavior?
Brad Turpin
(4,110 Views)
Hello Brad,
Thanks for your response the code thats giving me trouble is as follows
    Set connection = CreateObject("ADODB.Connection")
    query = "SELECT " & target_type & " FROM TableExample1 WHERE " & source_type & " = '" & source_code & "' " &_
            " UNION SELECT " & target_type & " FROM TableExample2 WHERE " & source_type & " = '" & source_code & "' "
    Set record_set = connection.Execute(query)
    If Not record_set is Nothing AND NOT record_set.EOF then
      record_set.find source_type & " = test"
    End If
There are a couple of things worth mentioning
firstly I'm using diadem V 8.10;
secondly the word "find" turns red;
thirdly the error message given is as follows "Arguments are of the wrong type, are out of acceptable range...."
I know there are other ways of creating a record set are these worth trying?
Lewis
(4,081 Views)
Hello Lewis!
The reason for the error is that in VBS optional parameters of COM objects are set to Empty if they are not defined (might be different to VB!). In the find method Empty values are not valid for the parameters 2, 3 and 4.
Try this:
record_set.find source_type & " = 'test'", 0, 1, 1
Note 1: I also added the single quotes around 'test'
Note 2: The DIAdem syntax highlighting doesn't always show you the 'truth'Smiley Wink
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(4,076 Views)
Excellent, thank you Matthias that worked a treat Smiley Very Happy
(4,061 Views)
