DIAdem
export Time to CSV
Hello everyone,
I wrote a script that in the end should store all data to a CSV file. Unfortunately it writes the time down as following:
08/12/2009 16:52:52.5335464
this is correct but a little uncomftable to process so I want to ask you what do i have to do so the time is written like this:
manyDigits52.5335464
or even better how do i get the time starting with 0 for the foirst measurement?
Thanks in advance
H.Wagner
(3,878 Views)
Accepted by noname76
If you set the property "displaytype" of the time channel to "numeric" instead of "time" DIAdem will export a double representing the seconds till 01.01.0000
To work on with this numbers heer are some constants
const __int64 SECONDS_1_JANUARY_1904 = 60084288000; ///<! Seconds form 01.01.0000 - 01.01.1904
const __int64 SECONDS_1_JANUARY_1970 = 62167132800; ///<! Seconds form 01.01.0000 - 01.01.1970
const __int64 SECONDS_1_JANUARY_1601 = 50522659200; ///<! Seconds form 01.01.0000 - 01.01.1601
which can be used to transform to other time bases.
After the export you can set the "displaytype" back to "time".
(3,865 Views)
-Hello AndreasK,
thank you for your reply. This worked like a charm. For everyone else having the same issue here the ccomplete code:
Data.Root.ChannelGroups(1).Channels("Time").Properties.Item("displaytype").Value="numeric"
Thanks again
H.
(3,855 Views)
