DIAdem
extracting date and creating a new channel
How do I take a date format like 1/12/2013 and create a new channel with just the month, and one with just the year ?
I want to be able to look at month over month trend on data.
(5,338 Views)
Hello Jcheese,
assuming your time channel is "Time", and all channels are in the first group:
Dim i
Dim oCh_source : Set oCh_source = Data.Root.ChannelGroups(1).Channels("Time")
Dim oCh_date   :   Set oCh_date = Data.Root.ChannelGroups(1).Channels.Add("Date",DataTypeFloat64)
Dim oCh_month  :  Set oCh_month = Data.Root.ChannelGroups(1).Channels.Add("Month",DataTypeFloat64)
Dim oCh_year   :   Set oCh_year = Data.Root.ChannelGroups(1).Channels.Add("Year",DataTypeFloat64)
For i = 1 To ChnLength(1)
  oCh_date(i)  = Val(Str(oCh_source(i), "#MM/DD/YYYY"))
  oCh_month(i) = Val(Str(oCh_source(i), "#MM"))
  oCh_year(i)  = Val(Str(oCh_source(i), "#YYYY"))
(5,322 Views)
Accepted by topic author Jcheese
Hello Jcheese,
In addition to Dia791 suggestion you have to other possible ways in DIAdem 2012:
A) Using the VBS commands YEAR and MONTH
Dim i
Dim oCh_month  : Set oCh_month = Data.Root.ChannelGroups(1).Channels.Add("Month1",DataTypeFloat64)
Dim oCh_year   : Set oCh_year = Data.Root.ChannelGroups(1).Channels.Add("Year1",DataTypeFloat64)
For i = 1 To oCh_source.Size
  oCh_month(i) = month(oCh_source(i))
  oCh_year(i)  = year(oCh_source(i))
B) Using a DIAdem command:
Call Calculate ("Ch(""[1]/Month"")= RTP(Ch(""[1]/Time""), ""M"")")
Call Calculate ("Ch(""[1]/Year"")= RTP(Ch(""[1]/Time""), ""Y"")")
Greetings
Walter
(5,312 Views)
worked thanks
(5,300 Views)
