DIAdem
surface plot issue
I am facing a problem with a characteristic diagram in which I would like to display a Z-channel against an X and Y channel. The Z-channel is basically composed of 3 different values (0, 10 and 110) and I would like to link a color  to these values. Therefore, I defined a contour table (here enclosed) and I selected the option surface + from contour table.
The point is that I obtain a graph with only one color (instead of 2 defined in the contour table, graph also enclosed). Is there something missing in my countour table? or in the graph options?
Thank you very much for your support
Jérémy
(5,185 Views)
Hi Jérémy,
I created an example in DIAdem 2012. Did you mean that?
Greetings
Walter
(5,173 Views)
Yes I meant that, I think my problem was due to the values I put in my contour table...
thank you very much 🙂
Jérémy
(5,167 Views)
