DIAdem
freetext resultant size and trimming
I have a freetext object on my report.  I set the object to have background color and a frame.
The frame has no padding and is right next to the text. I didn't like that and added spaces before and after text.
some padding was created before the text but apparently the whitespace is trimmed from end. sample attached
how can i get some padding space AT END OF TEXT?
alternatively, how do get the length of the rendered text? in report units... i don't want courier font
jim
BTW, i still couldn't attch a TDR to post
(4,210 Views)
Hello Jim!
AFAIK: No way!
Solutions for these problems wich works in other programs e.g. the ANSI char with code 160, doesn't work with the 'special' implementation of text rendering in DIAdem. The sub-optimal aproach is to use a filled rectangle and a free text. But this will have other drawbacks...
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(4,200 Views)
it seems to me that after rendering, the size is known and could be retrieved.
jim
(4,146 Views)
