11-20-2009 12:42 PM
I have a freetext object on my report. I set the object to have background color and a frame.
The frame has no padding and is right next to the text. I didn't like that and added spaces before and after text.
some padding was created before the text but apparently the whitespace is trimmed from end. sample attached
how can i get some padding space AT END OF TEXT?
alternatively, how do get the length of the rendered text? in report units... i don't want courier font
jim
BTW, i still couldn't attch a TDR to post
11-21-2009 02:01 AM
Hello Jim!
AFAIK: No way!
Solutions for these problems wich works in other programs e.g. the ANSI char with code 160, doesn't work with the 'special' implementation of text rendering in DIAdem. The sub-optimal aproach is to use a filled rectangle and a free text. But this will have other drawbacks...
Matthias
| Matthias Alleweldt Project Engineer / Projektingenieur | Twigeater? |
11-30-2009 09:29 PM
it seems to me that after rendering, the size is known and could be retrieved.
jim
