DIAdem
how to include a variable in a formula calc
I need to do some calc formula to help my report but I encounter a problem.
I use this formula to erase some data from my channel but the formula don't reconize my variables.
R4 = CMax(Ch("[1]/TRAVEL_DISTANCE"))
Call DataBlDel("[1]/TRAVEL_DISTANCE_SMT",ChnFind("Ch(""[1]/TRAVEL_DISTANCE"")>R4",1),2000,1)'... ChnNoStr,ChnRow,ValNo,ValDelOnly , but the formula for the ChnRow don't see the variable R4, and if I put " before R4( to make R4 green) I receive an error : Expected ')'.
Please tell me how I can use a variable in a formula , so the formula can see it.
(5,291 Views)
Hi Marse,
You were missing a couple of parentheses.  It's much easier to debug if you break up the expression into its components and then add the resulting parameter (Row) into the final function (DataBlDel):
Row = ChnFind("Ch(""[1]/TRAVEL_DISTANCE"")>R4", 1)
Call DataBlDel("[1]/TRAVEL_DISTANCE_SMT", Row, 2000, 1)
Brad Turpin
DIAdem Product Support Engineer
(5,279 Views)
Hi Brad,
I try in your way but it still not working, the problem is with the formula for the Row parameter, it takes the 0 value, and int the "Call DataBlDel" statement I have 0 value to the Row, and I receive the error from the attachament.
I thing the problem is because the formula don't see the R4 variable, and like I said to you if I put (") before R4, Diadem tell me : Expected ')'.
Please tell me how can I make R4 visible in the  Row formula.
Thank you  for your time.
(5,263 Views)
Hi Marse,
imo there is a logical mistake.
You are looking for the maximum of a channel (R4).
Then you are looking for a value which is bigger (>) than R4 in the same channel.
It's impossible, insn't it?
greets Andreas
Volkswagen AG
Wolfsburg - Germany
(5,259 Views)
Accepted by topic author Marse
Hi marse,
The smiley face inserted by the text editor got in our way.  If you replace the smiley face in my reply with a "close-parenthesis" character, then the code will run correctly.  I have to admit, though, that there does appear to be a logic error, despite the fact that the code ran correctly on the data set I tried it with.  But finding the row of the peak is something you can do less ambiguously and more easily with the PNo() function:
Row = PNo("[1]/TRAVEL_DISTANCE", R4)
Brad Turpin
(5,251 Views)
Thank you Brad, it help me. Now it works fine.
I realize that the smiley face means a "close parenthesis", but it still not works in that way.
Thank you again for the advise with PNo, now it is ok.
(5,232 Views)
Hi Hass,
Now that you tell me it has sens.
Now it is logic why the formula didn't work.
(5,230 Views)
