DIAdem
irig106 Data Plugin to read .ch10 extension file
Hi forum,
                I am trying to read the IRIG106 (.CH10)  using dataplugin IRIG106 dataplugin   http://www.ni.com/example/31585/en/
Can any one help me how to read a file using this dataplugin either in LabVIEW or Diadem.
I have tried using this dataplugin to read IRIG106 (file Extn .ch10) in LabVIEW but LV is getting crashed without any reason !
thanx in advance.
(8,305 Views)
Hi A_LI,
Let's try first with DIAdem, which is easier, then we can make it work in LabVIEW.  Can you send me a sample IRIG data file for me to test with?  Or you could email it to me at brad.turpin@ni.com.
Brad Turpin
(8,271 Views)
hi Brad,
              thank you for your quick reply i have mailed you the sample file and i will would wait for your response
(8,240 Views)
Accepted by A_LI
Hi All,
The changes made to the IRIG_106 DataPlugin to read these new data files were posted to the www.ni.com/dataplugins website today.
Brad Turpin
(8,086 Views)
Any way you can port this IRIG-106 Chapter 10 format to LabVIEW?
(5,186 Views)
Hi Sean,
The Storage VIs (off the File I/O palette) enable you to use any DataPlugin in LabVIEW.
Brad Turpin
(5,183 Views)
