DIAdem
is there any way to dynamically choose folder when using dirlstwrite to make a file list?
For data in many folders, I need dynamically choose folder to make file list one after one. is there any way to dynamically choose folder when using dirlstwrite to make a file list?
(3,336 Views)
Sorry, but this is not possible without manually programming in VBS. The command DIRLSTWRITE contains a parameter variable: FileLstFilter which specifies which information DIAdem saves when it performs the DirLstWrite command.
onlyFilenames: Only filenames
onlyDirectorynames: Only folder names
filenames: Filenames and file extensions
fullFilenames: Complete filenames
With this parameter you can create a list of sub folders to use them with DIRLSTWRITE again.
I hope this will help you
Greetings
Walter Rick
(3,336 Views)
