DIAdem
memory heap issues
Hello All,
We are making a report in DIAdem with three waterfall displays. At the second or third we get a 'memory heap' problem.
If we limit the number of colors on one of these we get the 'memory heap' problem at the third.
Se we added some more RAM (2 GB) but the memory usage of DIAdem stayd low (64 meg), we modified the envirenmentals to use a 1 GB heap, but still DIAdem stayed low in RAM.
We have placed the DIAdem swap on a 100 GB disk, but still no valid report.
The funny thing is the waterfall display is plotted correctly, but the z-axis label is missing the numbers....
Sorry I can't show a screenshot of the error, maybe later when my colleague returns.
Ton
My LabVIEW Ideas
(3,424 Views)
Hi Ton,
Could you give me some more information about your DIAdem version and the amount of data you are trying to display (how many values per channel, how many channels)?
I'll try and reproduce this on my PC once I have an idea about the environment you are working with,
    Otmar
Otmar D. Foehner
(3,405 Views)
