DIAdem
merging calculation groups
The calculation Manager allows you to export a calculation group. Now I would like to import that set of calculations into a different .tca file. How can that be accomplished?
I would like to merge the two .tca files
(1,109 Views)
Hi qfman,
You can append a calculation set to another. If you need only a single calculation group, you can store remove all not needed groups and save the group of interest temporary. Then you append this temporary calculation set (with only one group) to others.
Greetings
Walter
(1,073 Views)
