DIAdem
msgbox not appearing
I was writting and script and tried to add a msgbox to make sure that my script was working correctly up to that point. When  added it nothing appeared. then i wrote a simple one.... nothing any ideas? is there some sort of setting that i need to change. I'm pretty new to diadem.
my simple script (as simple as they come):
sub hello ()
msgbox("hello")
end sub
and i got nothing... is there something wrong with my syntax? any help would be great. thanks
(4,574 Views)
Accepted by adevins76
Hello!
Silly question: Do you call the sub somewhere?
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(4,567 Views)
yes
(4,565 Views)
AFAIK is there no setting that can cause this strange behaviour. What you can try, just to see if it makes a difference, is to use the old fashioned MsgBoxDisp command.
Matthias
Matthias Alleweldt
Twigeater?
(4,563 Views)
Previosuly you asked whether i called the sub or not. I tried just running this sub as its own independant sub, is there something else i need to add to the code or elsewhere. im kinda new to coding so i apologize for lack of knowledge
(4,560 Views)
If you define a sub you have to call it. Try this code:
Call hello()
sub hello ()
  msgbox("hello")
end sub
Matthias
Matthias Alleweldt
Twigeater?
(4,555 Views)
