DIAdem
o2DCurve.Shape.XChannel.Reference & Joint x-axis setting
I'm on Diadem 2012 and do a lot of calculations in VBS that save some time. As a cherry on top there is a generator that loads TDR report file and inserts data from channels as curves.
o2DCurve.Shape.XChannel.Reference that should insert the correct channel. However it does not:
I spotted the problem in the second it uploaded here...
This is caused by the "Joint x-channel" checkbox in lower-left. Is there a property that changes that? Right click in Report>Copy as Script does not show anythig of related name (to my eagle eye at least).
(4,530 Views)
Accepted by topic author cubz
Hello cubz,
I think this might be the parameter you are looking for:
Report.ActiveSheet.Objects.Item.Settings.UseCommonXChannel = False
Example code (will delete your existing layout):
Dim oMy2DAxisSystem, oMyPos, oMy2DCurve1, oMy2DCurve2
Call Report.NewLayout()
Set oMy2DAxisSystem = Report.ActiveSheet.Objects.Add(eReportObject2DAxisSystem, "My2DAxisSystem")
Set oMyPos = oMy2DAxisSystem.Position.ByCoordinate
oMyPos.X1 = 20
oMyPos.X2 = 80
oMyPos.Y1 = 20
oMyPos.Y2 = 80
Set oMy2DCurve1 = oMy2DaxisSystem.Curves2D.Add(e2DShapeLine, "MyNew2DCurve1")
Set oMy2DCurve2 = oMy2DaxisSystem.Curves2D.Add(e2DShapeLine, "MyNew2DCurve2")
oMy2DCurve1.Shape.XChannel.Reference = "[1]/[1]"
oMy2DCurve1.Shape.YChannel.Reference = "[1]/[2]"
oMy2DCurve2.Shape.YChannel.Reference = "[1]/[3]"
oMy2DAxisSystem.Settings.UseCommonXChannel = True
Call Report.Refresh()
I hope that's helpful,
     Otmar
Otmar D. Foehner
(4,515 Views)
Hi Otmar,
yes, that's it. Thanks, now I can generate more of the reports without worries for the .TDR!
P.S: Friday note: the eReportObject2DAxis​System is wrong when one copypaste the code you posted directly into Diadem.
Cheers,
c.
(4,504 Views)
