DIAdem
"No valid source or target channels specified. Cannot execute." error when attempting to convert from waveform to numeric channel
I'm trying to convert a waveform channel into a numerical channel and an absolute time channel, but I get the "No valid source or target channels specified. Cannot execute." error.
I'm attempting to concatenate multiple InsightCM TDMS files so I can view the data as one continuous stream over time. If I convert the same channel from the first file loaded (any of the channels in the "Waveforms" group), it works fine, but when I try doing the same thing with any of the channels from the second file (any of the channels in the "Waveforms1" group) I receive the error.
(4,574 Views)
Accepted by JEBalles
Hi JEBalles,
I was able to reproduce that behavior when I selected a Numeric Channel as my Channels to be converted. In this case, it looks like you're running the operation on the Speed Profile>>Mod1-Ch0 A NL, which is a Numeric Channel.
Could you try selecting a another waveform Channel? It looks like [3] Mod1-Ch0 A NL is a Waveform channel.
Nadine H.
Applications Engineer
(4,544 Views)
Ah yes, you are correct - I was choosing a numeric channel. I was interpreting the [2] as the file, not the channel group.
(4,520 Views)
