DIAdem
reading independant values in a channel
I want to read the value of a chanel.
I suppose that every chanel is store like an array with an index and a value.
I would like to read a value of a chanel with his number index, then make some computations and then write in it.
For exemple:
Chanel 1:
index value
1           1
2           1
3           1
4           2
5           1
6           1
at beginning index = 0
value>1?
if no check the next one
if yes do something
Do you have an exemple of script to read a single value in a chanel?
Frederic MANUEL
(5,046 Views)
Can you please let us know which DIAdem version you are using ?
(5,044 Views)
sure 🙂
Its the evaluation version, 2012
(5,041 Views)
Accepted by fmanuel
Ok, then this should work
Dim   oChn,K,dValue
' get access to the channel you are interested in
Set oChn = data.GetChannel("Time")
' loop over all values
For K = 1 To oChn.Size
  dValue = oChn(K)
  If ( dValue > 1 ) Then
    ' do something
    MsgBox(" Value GT 1")
  End If
(5,038 Views)
that is what i was searching, thank you for fast solution 😉
(5,034 Views)
