DIAdem
resample to reduce data of a channel
Hi all,
I am simply looking for the VBS code to reduce the number of samples in a channel by two or four. The command should reduce the data by means of averaging. I am convinced it is a very simple command, and I feel annoyed that I wasn't able to find a way to do it.
Aart-Jan
(4,289 Views)
Hello Aart-Jan!
See the thread http://forums.ni.com/ni/board/message?board.id=60&message.id=5832#M5832 and my solution. This should work for you as well.
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(4,281 Views)
