DIAdem
root properties in connected data store: error when accessing storage date/time
When browsing through the properties of my connected data store I get an error message when trying to read the property value of "storage date/time": Object doesn't support this property or method.
Here is a minimum example:
Dim oMyDataStore, MyProperty, oMyProperties
Set oMyDataStore = Navigator.ConnectDataStoreByParameter("TDM", "<filename readonly=""yes"">"& "C:\Program Files (x86)\National Instruments\DIAdem 2012\Examples\Data\Example_data.tdm" & "</filename>")
Set oMyProperties = oMyDataStore.RootElements(1).Properties
For Each MyProperty in oMyProperties
  Call MsgBoxDisp("Property name: " & MyProperty.Name & vbCrLf & "Property value: " & MyProperty.Value)
Why can I not access this particular default property?
(5,910 Views)
Accepted by Phex
Hi Phex,
for date/time properties an object called UsiTimeDisp is returned. This object allows you extended service functionality like accessing each part (day, year, hour, seconds, ...) of your date/time value separately. If you want to print the date/time value with MessageBoxDisp you can use the VariantDate property of this object.
Your code could look like this then:
  If MyProperty.DataType = eTime Then
    Call MsgBoxDisp("Property name: " & MyProperty.Name & vbCrLf & "Property value: " & MyProperty.Value.VariantDate)
  Else
  End If
I hope this helps.
Have a nice day,
Eva
(5,900 Views)
Hi Eva,
thanks for your help, appreciated.
/Phex
(5,896 Views)
