DIAdem
save settings for rainflow-analysis at DIAdem-Script
I wrote a script with DIAdem-Script. This script does a rainflow-analysis from a signal.
My problem is that I need 64 steps but the standard setting is 8 steps.
I program the rainflow-analysis with 64steps in DIAdem-Script and the script does is till I shut down DIAdem.
If I restart DIAdem and load the script with the 64step-rainflow-analysis, it makes only 8steps (the standard setting at my Diadem).
Now I want to know what I can do to solve these problem.
I want to have a script that makes a rainflow-analysis with 64steps at any time.
(3,314 Views)
Hi Christian,
We should be able to get this to work as you desire it.  These are the variables behind the class number dialog in the Rainflow calculation:
CLASSMETH2      = "Automatic"
CLASSNO         = 10
CLASSWIDTH      = 0.0389656847322041
CLASSBEGIN      = 0.50634440282565
CLASSRANGEWIDTH = 0.389656847322041
CLASSEND        = 0.896001250147692
What combination of these variables are you using and which values are you assigning them?
Brad Turpin
(3,305 Views)
