DIAdem
script for combining two channels
Hi all,
My task is to load two dat files.
Time channel is common in both the dat files. So keeping it as reference, How can i compare the rest channel values with each other??
Manually am doing,
1. Load 2 dat files from navigator
2. Copy all channels from dat file 2(except time channel) , to dat file 1
3. Delete the dat file 2 from data portal.
4. Now you have only 1group/1 channel with values of two different dat files and plot them on graph.
5. While plotting them on graph, x axis would be time(which is common) and y axis would be S1KNSLLE00H3DSZP and S1KNSLLE00H3DSZP of two different dat files.
How can i automate this. Any inputs on this?? Attached is the sample dat files
(3,631 Views)
Hi Rash.patel,
I see no reason to rearrange the data channels.  Data Portal Groups were created for exactly this sort of use-case, where you want to compare the same channel from multiple data files at the same time on the same graph.  Just load the 2 *.dat files normally and drag the Time+Data channel pair from each Group onto the VIEW or REPORT graph.  I'm enclosing an example VIEW layout that I believe does what you asked for without having to move any channels around.
Brad Turpin
DIAdem Product Support Engineer
(3,613 Views)
