DIAdem
string channel size
Hi All,
I have been working with a channel with the data type String and fill in values with a script. This channel gets really big, it has been over 4 000 000 values long some times. It worked perfectly fine just last week. When I tried to run my script today it woud throw an error message that the index 262145 is outside the valid range for the values property.
Numeric channels work ok and I didn't change anything in the script related to my channel.
What could be the problem?
    Christoph
(5,170 Views)
Hi Christoph!
Can you send me the error code you get with your message?
I'd like to take a look at this.
Eduard Gross
(5,152 Views)
Accepted by FraCh
Hi Eduard,
That's a bit embarrassing... I've tried everything but restartung DIAdem...
It was merely a lack of memory. Sorry to have bothered you.
    Christoph
(5,147 Views)
Hi Christoph,
that's not a problem.
I'm glad to hear you got the issue resolved.
Have a nice day,
Eduard Gross
(5,140 Views)
