DIAdem
tdm data path defination
first name.last name<at>ni.com
Message 11 of 14
(2,111 Views)
Hi Walteer,
i have sent the dataset to your emailbox.
Message 12 of 14
(2,108 Views)
Hi Andreas,
I had a similar problem before, if you look carefully to your path it says:
"C:\Dokumente und Einstellungen\TDM2012-05-14 1834 VF-028 Nano IMT Indonesia-Java.TDM"
and it should be
"C:\Dokumente und Einstellungen\TDM\2012-05-14 1834 VF-028 Nano IMT Indonesia-Java.TDM"
Seems to me that for some reason the function sometimes misses the last character of the string so what I did was check this last character using the function right( string,1). if this character is <> to then add it to the path.
Perhaps it's not the most professional code but...it worked...
Javier
Message 13 of 14
(2,075 Views)
Hi Javier,
thank you very much. I am so careless. I just put the TDM data and script together, then works. Now i have a better idea.
Best Regards
Andreas
Message 14 of 14
(2,066 Views)
