DIAdem
tdm file format help
I'm writing a program in delphi to export data to tdm file format throught DLL library. I have a problem defining some data types.
example:
int DDC_CreateFile (const char *filePath, const char *fileType, const char *name, const char *description, const char *title, const char *author, DDCFileHandle *file);
-this is a function to create a file. Where can I get the type of DDCFIleHandle structure?
I have a "DIAdem connectivity library help" but I can not find these definitions.
Thanks for Help!
(3,254 Views)
Hello Rocky123,
In the help file, the parameter is explained as an output:
Name Type Description
file DDCFileHandle The handle for the DIAdem file. Pass this handle to DIAdem Connectivity Library functions that require a file. Call DDC SaveFile to save the file to disk. Call DDC CloseFile to close the file handle when you are finished.
The file handle is a return parameter ofg the function, just pass a variable to the function and the filehandle will be stored into it.Please refer to the examples that ship with the DLL.
Message Edited by IngoS on 08-27-2007 01:24 PM
Ingo Schumacher
Systems Engineering Manager CEERNational Instruments Germany
(3,250 Views)
