DIAdem
tdms.dll error loading file in DIAdem
I'm trying to load a TDMS file written in LabVIEW 2010 into DIAdem 2010, but receive the attached error indicating an ACCESS VIOLATION in tdms.dll.
I have several machines that this file loads into DIAdem 2010 fine on, but of course the one I need it to work on is the only one that it doesn't work on.
The machine in question has a "fresh" install of Windows XPSP3 with minimal other stuff installed (it's a Dell Optiplex GX620, if that mattters).  As mentioned, the file loads fine on several other machines with DIAdem 2010 on it.  The machines that it works okay on are running Windows XPSP3, XPSP4 and Win7 (all Dell machines).  I have attached a list of installed applications on the PC in question.
Any one have any thoughts?  Are there any programs that are incompatible with DIAdem?  Are there any installers that DIAdem (or tdms.dll in particular) depend on that need to be installed also?
Joe Gerhardstein
Viasat
Certified LabVIEW Architect
Certified TestStand Developer
http://www.viasat.com
Message 1 of 8
(4,856 Views)
Could you please compare the tdms.dll version on the sytem that works and the system that does not.
Option Explicit
dim fsi : set fsi = CreateObject("Scripting.FileSystemObject")
dim wsh : set wsh = CreateObject ("WScript.Shell")
On Error Resume Next
dim niSharedDir  : niSharedDir  = wsh.RegRead("HKLM\Software\National Instruments\Common\Installer\NISHAREDDIR")
dim tdmsDirRef       : tdmsDirRef       = niSharedDir & "tdms\"
dim tdmsVersion : tdmsVersion = fsi.GetFileVersion(tdmsDirRef & "tdms.dll")
msgbox tdmsVersion
Message 2 of 8
(4,848 Views)
The ones that work are all 2.2.1546.609.  The one that doesn't is 2.2.1496.920.
Is there a way to update this?  Can I just copy the DLL across, or are there other DLLs that need to be updated at the same time?
Joe Gerhardstein
Viasat
Message 3 of 8
(4,845 Views)
Accepted by Joe_Gerhardstein
I copied the newer DLL over to the machine that didn't work, and that seems to have fixed the problem.
Does LabVIEW 2010f2 install a newer version of the DLL than DIAdem 2010 does?
Joe Gerhardstein
Viasat
Message 4 of 8
(4,837 Views)
There is an update installer at
http://zone.ni.com/devzone/cda/epd/p/id/3008
Better put back the old version and run the installer.
Takes you to the safe side for future updates.
Message 5 of 8
(4,834 Views)
So, before you provided the link to the updater, I did a search on USI (which I believe is the underlying driver for TDM/TDMS) on the driver update page (http://www.ni.com/drivers/).  Any idea why this patch doesn't come up?
Joe Gerhardstein
Viasat
Message 6 of 8
(4,800 Views)
In this case it is a two layer access.
tdms is an own component. If the native tdms VI's are used LabVIEW does not access USI.
DIAdem access tdms by USI.
So in this case only the tdms component is updated/fixed and USI just makes use of the new
TDMS component. So USI does not change at all.
Its a dependence graph.
DIAdem depends on USI
USI depends on TDMS
Message 7 of 8
(4,795 Views)
I feel like an echo 🙂
Does not like my browser
browser
browser
brow
browser
brow
b
browser
brow
Message 8 of 8
(4,794 Views)
