DIAdem
the installed version of internet explorer might not be current - ERROR
While clicking on examples and used by in help i am getting error as attached. How can i see examples other than this method.
(5,076 Views)
Hi GDU,
What version of DIAdem are you using?  What version of Internet Explorer do you have installed?  I've never seen this error before.
Brad Turpin
DIAdem Product Engineer
(5,072 Views)
Internet Explorer Version 8 RC1
Diadem Version: 10.2
for more details check attachments
(5,060 Views)
One more error related to installation of DOL plugin (http://zone.ni.com/devzone/cda/epd/p/id/6345)  see attached error:1316 some network problem i think its Microsoft's problem
(5,054 Views)
Hi GDU
The problem you have is not DIAdem specific but all help files of your system will have this problem. If you open for example the "Windows Help and Support Center" (Start >> Help and Support) and try to click any "Related topic" on the bottom of any page this will not work. Because we knew this problem could be caused by an old version of the IE we show the message, but it should only say that the related functionality is no available.
Up to know we only know that this problem could occur if you use a very old IE (Version 4 or 5). The related ActiveX was updated with a IE 6 or later.
To solve your problem please give me some more information.
Do you have Windows XP Service Pack 3 installed?
Have you installed all windows updates?
Have you try to install a release version of IE8? I know that some of the beta versions had this problem.
In the meantime we will try to found a solution of this problem.
Winfried
(4,975 Views)
Accepted by GDU
Hi GDU
Please install the following update on your computer. This will update the the Hhctrl.ocx to version 5.2.3790.2847
http://www.microsoft.com/downloads/details.aspx?FamilyId=74AD4188-3131-429C-8FCB-F7B3B0FD3D86&displa...
You can check the current version of your system if you right click on the task bar of the help file and select "About HTML Help..."
Please let me know if you still have this problem.
Winfried
(4,972 Views)
Thanks.
it works
(4,958 Views)
