02-19-2009 12:35 AM
hi
i dont know how i can split channel into pieces. in attachmeents i have piece of my data, i have there data which are use to axis X and axisY on my graph. In my data i have many cells where i have "novalue"(it is result from many calculation) and on graph it isnt curve but only many points, it look like curve but isnt, but it is not big problem. data from channel "axis X" show when new cycle is strated (one cycle= 0,25...as long as 719,75). I must in some way separate cycle(split channel into cycles) and calculation (receive) one average cycle. How i can do it ??
02-19-2009 02:12 AM
03-06-2009 02:14 AM
03-06-2009 10:17 AM
Hi again Elwis,
Your data looks mighty familiar, but I'm going to assume that this latest data set came from a different source than the other VBScripts I wrote for you. Here's an example of how to start with the data as you have it in Excel and morph it into the same output that you wanted before.
Brad Turpin
