DIAdem
user defined variables
Hi all,
I am using the variable L3 in my code for channle assignment. In line number 18 it gives error ch(0): INvalid channel or vector matrix.
I have the channels loaded in my data portal and defined user variables as : F <" "> and linked user variables file.
How can i correct the line 18 and 19 to make it work. Please help out...
Rsh
(3,945 Views)
Hi RSH,
There are almost no reasons left to use the old *.VAS file approach to creating customer-defined global variables in DIAdem.  The OdsValAlloc() approach is cleaner and more dynamic and just as robust, and the GlobalDim approach is cleaner and much more flexible.
I'm going back and reviewing the Summer's posts-- is this still an issue for you?
Brad Turpin
DIAdem Product Support Engineer
(3,718 Views)
Hi Brad,
Nice to see you back on screen.. 🙂   Thanku, I solved this issue...
Rsh
(3,697 Views)
