DIAdem
which edition can use Report.Sheets.Copy?
Hello All:
My question is: what is the most early edit "Report.Sheets.Copy" can be used?
cause the warning "type match Report" always pop up when I use DIAdem 10.2.
Dim oMyFirstSheet, oMyNewSheet
Set oMyFirstSheet = Report.ActiveSheet
Set oMyNewSheet = Report.Sheets.Copy(2,"Sheet1",1)
(2,956 Views)
Accepted by DinaDing
Hi DianaDing,
DIAdem 2012 is the first version which supports the REPORT-API and with that also the command
Report.Sheets.Copy...
Greetings
Walter
(2,948 Views)
Hello Walter:
Thanks a lot for your information. My Diadem is 11, which obviously doesn't support this command. I will try some other ways to solve this problem.
(2,913 Views)
