DQMH Consortium Toolkits Feature Requests
FireFist-Redhawk
Add New (Custom) DQMH Module - Pre-populate Overlay
Status: Released
As DQMH module templates become more widely used, it would be very nice if, when adding a new DQMH module that was added as a custom template, the overlay pre-populated with the overlay that the template uses.
So maybe thinking about this on a lower level, this feature request comes in two parts. When saving a DQMH module as a template, store the metadata that makes up the current overlay in a config file somewhere. Then, on the Add New DQMH Module window, whenever a custom Module Type is selected, pre-populate the overlay with that metadata.
Redhawk
Test Engineer at Moog Inc.
Saying "Thanks that fixed it" or "Thanks that answers my question" and not giving a Kudo or Marked Solution, is like telling your waiter they did a great job and not leaving a tip. Please, tip your waiters.
1 Comment
Olivier-JOURDAN
Active Participant
Status changed to: Released
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn
Stop writing your LabVIEW code documentation, use Antidoc!
