Original idea from @FabiolaDelaCueva
Sometimes you could need to unregister broadcast events. To do this you want to use the Broadcast Events--cluster.ctl, but it's set to private scope (it's totally fine).
Having a public wrapper to this control just giving access to the type and not the current event like you can get with Obtain Broadcast Events For Registration function would be great.
Considering providing a fixer to add this wrapper to all other existing modules.
Issue #749 created
