| User | Kudos |
| 3 | |
| 3 | |
| 2 | |
| 2 | |
| 1 |
Today when creating adding a module template it is not possible to set a 'human readable' name for template.
The template name is the module's library name. Having a field to specify a more friendly name could be useful (could be set by default withe the module's library name though).
Available with DQMH 7.1
