When creating Request And Reply / Round Trip events, the timeout to get the answer is set as a constant which is global to the module.
It would be nice to personalize this timeout to choose between :
If Module timeout is selected, then module timeout -- constant.vi would be wired to the 'wait for notification' timeout input.
If Personnalized is selected the value set by the user would replace the module timeout -- constant.vi (using a constant instead, or better calling a newly create 'request name' timeout -- constant.vi)
