DQMH Consortium Toolkits Feature Requests
TiTou
Asynchronous enqueue with delay
Status: Declined
Hey TiTou, thank you so much for your trust in DQMH and for taking time out of your day to share your idea with us.
We believe this idea opens too many possibilities of misusing the framework and doing wrong things.
So, we decline this request, at least for the next DQMH version.
Again, thank you for your input; it is most appreciated. Please keep those ideas coming!
I recently started using this in one of my DQMH modules, it's a tiny feature and could be added to the DQMH palette.
The idea is to spawn a dynamic VI (using call and forget) that will wait a certain time (delay) and then enqueue a message in the MHL queue.
It allows to not block the MHL for other actions and make sure that a message will be enqueued with a delay.
It consists in 2 VIs, here's a simple demo :
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
8 Comments
Olivier-JOURDAN
Active Participant
Status changed to: New
I'm not a big fan of this method.
It will work in the nominal case but can be a source of complex issues to deal with.
I would better use a helper loop to deal with that. It's not dynamic. It stops as soon as the Stop Module is sent.
It's less generic but much more readable and debuggable.
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn
Stop writing your LabVIEW code documentation, use Antidoc!
joerg.hampel
Active Participant
TiTou
Trusted Enthusiast
@Olivier I understand you concern.
it's certainly a bit rough around the edges some of your concerns can be addressed (handle the stop module)
the lack of clarity / debuggability it less addressable
my use of this is in a module that communicates over the network with another module, when network is down, make sure we recheck again in 10 seconds, if the module is stopped in the meantime... well I don't care too much for that, the enqueue would fail, the error would be lost, I'm happy with this behaviour
Doing this with a helper loop would require to share a status with the helper loop... meh
Epictetus
Antoine Chalons
Olivier-JOURDAN
Active Participant
@TiTou I understand that your use case makes that you don't really care about what can happen in some conditions.
Concerning a new feature provided by DQMH we need to be as careful as we can to prevent users to misuse it.
My personal feeling about your proposition is that it opens too many possibilities to do wrong things.
Olivier Jourdan
drjdpowell
Trusted Enthusiast
If you want an existing example, Messenger Library has "Delayed Send" and "Send on next millisecond multiple".  These have been used for many years, though Oliver is not wrong to be wary of them.  Suggestions:
-- you need to poll the live status of your Queue, so that if your Module stops, your async VI will shut down.
-- Manage creation of your VI reference in the way the AF does (the way you show has a small timing hole)
TiTou
Trusted Enthusiast
Thank you both for your comments.
@Olivier : I understand your point about preventing misuse.
@James : I'll make the improvements
Epictetus
Antoine Chalons
drjdpowell
Trusted Enthusiast
Here is my instructional video for Messenger Library on this technique.  I think I discuss a few of the potential weaknesses of it as compared to a "Metronome" (which is close to how a "Helper Loop" in DQMH would behave):
mbaudot
Active Participant
Status changed to: Declined
Matthias Baudot | Software Architect | Founder & Owner at STUDIO BODs | DQMH® Consortium Board Member & Trusted Advisor
STUDIO BODs     LabVIEW Champion     Certified Professional Instructor     DQMH Trusted Advisor     DQMH Consortium Board Member     GCentral Sponsor
 Check out my LabVIEW presentations and videos!
