Most of the time we create multi-layer applications, and bottom modules need to share information that might have to cross several upper layers.
To avoid coupling and jumps between any non-adjacent layers, we have to create similar broadcast in the parent modules to repeat child broadcast one layer upper.
It would be interesting to have a utility that 'copies' an existing broadcast from one module into another.
And maybe have an option to code the forwarding :
- automatically register for child broadcast in the parent if not done already
- in the selected braodcast EHL case, map broadcast arguments onto parent broadcast VI inputs
I guess the same thing can be done when the communication needs to go down the layers, and therfore applied to requests.
Under consideration for a future DQMH release
