DQMH Consortium Toolkits Feature Requests
Labels
Top Authors
Taggart
Automatically Create Sequence Diagrams from DETT traces
Status: Declined
So far, I'm declining your suggestion because, in any case, if a tool is going to be released in the future, it will not be part of the framework itself.
@Taggart, thank you again for your help and your time writing down this suggestion.
Basically what I am looking for is something similar to this (except for DQMH)
https://forums.ni.com/t5/Actor-Framework-Documents/Actor-Framework-Sequence-Diagram-Parser/ta-p/3536...
It allows you to generate a trace with DETT and then use that as the basis for a sequence diagram.
A couple use cases:
1. You inherit a project that doesn't have any sequence diagrams. It would be nice to run this and see which modules launch which and how they communicate.
2. Troubleshooting - Things are supposed to happen in a certain order, but aren't working
3. Generating documentation - Let's say you didn't start by writing a sequence diagram, but now want to document the order things happen in.
I think this compliments the static diagrams in Anti-doc. Anti-doc clearly shows who sends broadcasts/requests to who, but doesn't show anything about timing.
@Olivier I think this would be a cool addition to Anti-Doc. It obviously couldn't generate the traces, but if you had a few, you could probably figure out how to point to them and include them. And maybe Anti-doc doesn't even run the tool on the traces. Maybe you run that seperately and then have antidoc render the resulting plant uml?
Sam Taggart
CLA, CPI, CTD, LabVIEW Champion
DQMH Trusted Advisor
Read about my thoughts on Software Development at sasworkshops.com/blog
GCentral
5 Comments
Olivier-JOURDAN
Active Participant
@Taggart I like the idea for Antidoc. I feel it's more an Anitdoc thing than a DQMH one. By the way, I encourage you to add an issue to the Antidoc project 😉
That being said, I have one question: how do you think the broadcast events should be treated? I feel that in many situations it would overcrowd the sequence diagram if all of them are represented.
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn |
Stop writing your LabVIEW code documentation, use Antidoc!
Olivier-JOURDAN
Active Participant
@Taggart From my previous comment, I'd add that if we want to draw the sequence in real-time it could be something the consortium can dive into (and we already have things working in that way and it could be used to improve Antidoc output...).
Just saying 😏
Olivier Jourdan
Taggart
Trusted Enthusiast
Added an issue here. Doesn't address drawing it in real-time.
https://gitlab.com/wovalab/open-source/labview-doc-generator/-/issues/164
Sam Taggart
GCentral
Olivier-JOURDAN
Active Participant
Speaking of drawing a sequence diagram in real-time, we demoed a tool during the GLA summit --> https://youtu.be/2kj7YI-a_xg?t=2697 that could do the job.
We don't know when this tool will be public.
Olivier Jourdan
Olivier-JOURDAN
Active Participant
Status changed to: Declined
Olivier Jourdan
