DQMH Consortium Toolkits Feature Requests
Thoric
Capture errors from the Exit case
Status: Released
Reviewing somebody's DQMH code I noticed an error generated in the exit case where they had cleanup code (1) was not captured by the Tester. This is purely because the exit case causes the MHL to terminate (2), so the normal error handling strategy (3) doesn't work (enqueuing another job called Error). Can I propose, unless there's a better technique, that adding the "Error Report" broadcast at the end of the Exit case (4) is a simple way to ensure any errors generated here get reported.
Add Error Broadcast in MHL Exit CaseAdd Error Broadcast in MHL Exit Case
Thoric (CLA, CLED, CTD and LabVIEW Champion)
1 Comment
mbaudot
Active Participant
Status changed to: Released
Matthias Baudot | Software Architect | Founder & Owner at STUDIO BODs | DQMH® Consortium Board Member & Trusted Advisor
STUDIO BODs     LabVIEW Champion     Certified Professional Instructor     DQMH Trusted Advisor     DQMH Consortium Board Member     GCentral Sponsor
 Check out my LabVIEW presentations and videos!
