When refactoring "Request" events into "Request and wait for Reply" events the scripting tools always create a new MHL case. If just wanted to modify the existing event I need to copy reply code, delete the new MHL case and add the reply code to the old MHL case..
It would be much better if the new MHL frame would be a checkbox option and the normal behavior is that the reply code just gets added to the original MHL case
In the helper loop this already works and the reply gets directly wired.
