DQMH Consortium Toolkits Feature Requests
CyGa
Convert module to match a template
Status: Declined
Hello Cyril,
Thank you for your continued involvement with DQMH and for submitting this feature request.
After discussing it with the DQMH Consortium and the DQMH Trusted Advisors, including yourself, we have decided to decline the request for now. However, as we plan to work on "merging modules" in the future, we may revisit this idea at that time.
We appreciate your input and look forward to your continued contributions.
The idea is to add a converter that would allow a 'plain' (standard) module to match a template.
Let's say I've got a Singleton module that contains logic a defined Public API and a template named MyVeryOwnSingleton.
I'd like the public API + MHL cases + helper loop of the Singleton module to be 'copied' into a new (?) module based on MyVeryOwnSingleton template.
A the end, I'd have a 'MyVeryOwnSingleton' module that exposes the same API as defined in the origin module + helper loop + MHL cases prepared.
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
1 Comment
mbaudot
Active Participant
Status changed to: Declined
Hello Cyril,
Matthias Baudot | Software Architect | Founder & Owner at STUDIO BODs | DQMH® Consortium Board Member & Trusted Advisor
STUDIO BODs     LabVIEW Champion     Certified Professional Instructor     DQMH Trusted Advisor     DQMH Consortium Board Member     GCentral Sponsor
 Check out my LabVIEW presentations and videos!
