This was originally raised by Joerg here:
To quote Joerg:
"Sometimes, the error cluster that feeds into the Delacor QMH Error Handler - Message Handling Loop.vi doesn't convey enough information to identify the origin of the error. For example, an Error "91 - Variant To Data in xyz.lvlib:Main.vi" does not tell me in which MHL case the variant to data operation failed. It would be nice to have the selector label of the MHL's case that the error occurred in."
Feature Request: Somehow (not sure what the best way would be) make the error handler include the last message's name (string) in the error broadcast."
